Old 12-31-2009, 05:56 AM   #65 (permalink)
Superturnier
My way is the low way
Superturnier's Avatar
MyoldFord - '65 Ford Taunus 20M Turnier
90 day: 27.59 mpg (US)
Plastic Spaceship - '94 Renault Espace
90 day: 24.03 mpg (US)
Sussu - '82 Suzuki Alto
Originally Posted by zjrog View Post
For my Jeep, I reset the computer last month and the last two fill ups have netted me 20+... Even with my daughter driving it. Better than the 17 though. So why don't I get better mileage when its warmer?
zjrog, What brand is your efi computer? Is it maybe Renix?
http://www.pirate4x4.com/tech/billav...ion_manual.pdf
The reason why I'm curious, is that I have noticed that my winter car gets better mpg when weather is colder. My winter car is a 1994 Renault (made in France) and it has renix type efi.
I'm monitoring the mpg daily with the MPGuino and this week I had some interesting results:
Yesterday morning:
Trip from home to work, 13km (8miles) Temperature -2C (29F) Engine block heater used 3 hours before start. FE resulted 6.7L/100km (35mpg)
This morning:
Same route, same pre-heating, only the temperature was different: -13C (8.6F) And FE resulted 5.8L/100km (40mpg)!
After resetting the computer (battery disconnected) the FE was much worse on this trip: 10,5L/100km (22mpg). There must be some kind of adaptation in the ECU. The next day things went back to normal. First I thought the bad FE was because I didn't use the block heater, but the reason is more likely the computer reset which I did at the same time.
I re-tested the effect of the block heater and it seems that using block heater does not make so much difference in FE. I got 6,3L/100km without block heater
So, Do any of you have an idea, why I'm getting better FE results when it's very cold (not just cold)? I think it must be the code inside the efi computer, maybe it has different mapping for different temperatures. Then maybe others with the same brand of efi could get similar results?
Last edited by Superturnier; 01-07-2010 at 08:17 AM.. Reason: Corrected my results about the use of block heater
