Old 12-31-2009, 02:13 PM   #8 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Update..................
Installed a spring on my pickup...put this one on the throttle rod above the pedal...with the spring anchored on a steel dash brace up under the dash. Made a "loop" to attach the spring at the pedal rod...using a small hose clap to hold it on.
Both vehicles (1.5 L and 2.4L-4x4s) are set to engage at around the same throttle position as at 55 mph in 5th gear.
With both I intend to shift at around 2.5K which is where both run in 5th at 55 mph...seems the combo is power enough to get down the road OK.
Expect both to save around 2-3 mpg vs more typical driving.
Probably a good idea to use a very small turnbuckle to adjust these...since the "slop" is only a fraction of an inch.
Specs for the truck:
vac at idle = 21 HG
vac at 55 mph in 5th = 10 to 14 HG....O2 cycles at this vac level...not if it goes below this though.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
