Old 12-31-2009, 06:47 PM   #37 (permalink)
shovel
Originally Posted by Old Tele man View Post
...you are missing the POINT, which is that NOT ALL engines achieve improved FE on ethanol blends!
Sorry, you are correct given the topic of this thread.
My argument was based on my assertion that it's OK to use more gallons of a physical substance if the net harm done by producing and consuming them is less than the other substance being compared, even if less of it is being used per work unit done.
Work From Home mod has saved more fuel than everything else put together.
