Old 12-31-2009, 11:19 PM   #17 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
1 ohm 10 watt resistor in series to view current
since you do have a DSO
Digital Storage Oscilloscope ?
you can use a 1 ohm 10 watt resistor in series with an Injector
since E=I x R or Voltage equals current multiplied by resistance
if resistance equals one E=I x 1 or E=I
or voltage = current , in that circuit , as per OHM's Law
you can connect your scope test leads across the 1 ohm resistor in series with an injector
you will see the SAME current image that i posted for your injector
in voltage
sequential injectors use less than 1 amp so set scope scale to 0 to 1 volt at about .5 ms per division to start then adjust to see image full screen .
place your cursors to get your actual injector on time
The Following User Says Thank You to mwebb For This Useful Post:
dave77 (01-06-2010)
