Old 01-02-2010, 12:45 AM   #88 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by bensenvill View Post
other way around
Are you talking about overdrive, or underdrive?
Overdrive is what the pulleys already are, where the driven cog is spinning faster than the drive cog.
Underdrive is used to slow the accessories down, to create less load on the engine. This is done by either making the drive pulley smaller, or making the individual accessory pulleys larger.
We've got to work out terminology here, because you've used both terms, and they're NOT interchangeable.
