Originally Posted by mcrews
Towing a car (implies it is not running) is completely different than coasting with the enigine ON!
Of course, you tow an automatic with the wheels up. Towing with the car off, wheels on the ground and the automatic in nutral is Bad for the auto transmission.
When you coast with the engine on and the car in neutral, the transmission fluid is still curculating bcause the engine and the electronics are on.
I always mix up coasting and EOC.
