Ben,
When you test fit the battery box one thing I like to do is "smooth out" the black strips of stuff that is in the trunk area. Sometimes they are a bit uneven.
Also if you have a smart key, the sensor is back there and one option is to unbolt it, cut off the bolt and grind the bolt down. Then secure the sensor nearby with zip ties.
Eric Powers
Your Hybrid Battery Hero
EV Powers Hybrid Battery Service and Repair
Madison, Wisconsin
www.evpowers.com
Reason: updated after I watched video 3 and saw that they cut the Enginer bracket.
