Old 01-02-2010, 09:07 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Please help me calibrate my SuperMID
I'd really appreciate it if someone could help me calibrate my SuperMid.
I recently took a trip of 134 miles in which my car got a weak 46.5 MPG.
The SuperMID distance parameter of 02565 is reading correctly, but the FE readings are way off.
According to the SuperMID, I got 62.24 MPG.
I have the fuel parameter set at 10475. What should it be set at ?
The car is a 1993 Civic with a 1.5L / automatic.
I also have a question that hasn't had an answer yet :
How are the settings on the SuperMID affected by things such as a tune up, or changes to the engine that were not present when the SuperMID was calibrated ?
I ask, because I may have my valves adjusted.
Will the parameters need to be re calibrated ?
Thanks
