Old 01-03-2010, 03:32 AM   #4 (permalink)
dwestmodesto
Did you use a mppt or a pwm charge controller. The mppt will yield between up to 33% more energy from the same solar cell aray. I am hoping to switch my controller that I use on my camping property up in Washington to the newer, better technology.
Good Luk,
DAve
Originally Posted by gascort View Post
yeah, the whole roof in panels puts out enough on a sunny day to allow me to drive for about 45 minutes. (summer)
Winter and I probably get enough to run for 20 minutes.
Those little guys probably have current ratings or wattage ratings so you could figure out how much power they have.
Power = voltage * current
(Watts = volts * amps)
If you have 2 watts of solar panel and you have it in direct sun for 3 hours, you have 6 watt - hours
Your car probably requires about 200 watts minimum to run (source)
6 watt hours divided by 200 watts = 0.03 hours that you could run your car on stored solar energy.
You might not even see gains from disconnecting your alternator. I saw negative MPG changes. Now I have a really expensive battery maintainer on my roof, lol. (unless I figure out how to get it to like running at 12V)
Matt
