Originally Posted by BamZipPow
Thanks Dave! You should read my build threads...
Let's see...
Coroplast, 4mm
1/4"-20 thread all
1/4"-20 "T" nuts (flattened out)
1/4" washers
Schedule 40 1/2" PVC pipe
zipties
shelf brackets
bolts
1"x2" wood
screws
As far as I know...I'm the only T-100 with a dropped and bumped air dam.
Gitting back on the subject...
I used a palm sander with some 1500/2000 grit wet/dry sandpaper to git most of the hard stuff off. The key in using this setup is keeping the surface wet with some soapy water in a spray bottle. I followed this up with some plastic polish on my buffer pad mounted on my drill. Sprayed it with a coat of clear and let that dry. Polished that down and sprayed it again. After that dried...I polished it one more time. Presto!
How long did the fabrication take you? Excellent work on the AD.
