Old 01-04-2010, 08:26 PM   #7 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
i've been reading and reading but im just a little slow to learn, i dont know how to use those templates for a deck lid, calculation, from what aerohead said i would calculate a 15 deg angle from my roof to the back edge of my lid ? and make the decklid hang off the trunk of my car far enough for the air to reattach ? do i stop it right at the 15 degree line or make it alittle longer for the air to reattach, also i think blocking it up a few inches to make it higher ,i can go about 3 inches and still see out the back window i would seal it against the trunk lid so no air would flow under it and also rubber gasket it against my back glass, also would vertical "wings" like the fusion flats racer help or is that for stability? i have a hard time figuring out what is for CD and what is for down draft. You guys are doing great work with this site and i have Too much to learn, i will post all my work with photos and a how to, if i can make the mods = good demonstrable gains. thanks for the template and seminars aerohead!
