Now i was just about to post a thread about this until i ran across this one. I've talked to alot of muscle car guys and heard from a few of you guys on here that With E85 as long as you advance your timing to work with it right it helps your car and runs stronger. I'm stoked about the 15 percent ethanol since my family owns older cars. As long as the timing is stepped up on the cars to work with it there should be no problems with this right?
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
