That makes sense then thanks for clearing that up. I tried to get my megasquirt conversion to idle at 14.7 afr with no luck at all. It bucks and stumbles like you woudn't believe. I'm hoping that once I switch from batch fire to sequential injection, I can lean out the idle afr. Also desperately need to upgrade the ignition system.
