Old 01-06-2010, 08:05 AM   #161 (permalink)
Daox
Andy, I moved your post to my main build thread for the car. If you want to see the progression of the car I would suggest reading this thread as it better explains my modifications.
I only ever enter fuel logs from actual fill up data at the pump. The scangauge and mpguino can get quite close, but I like using the raw data to be 100% sure.
Yes, the diameter of the tires are the same. I have not done gps or any other form of calibration. The Paseo and Tercel are very similar. The Paseo just comes with wider tires, but they have the same tire diameter. The 155s are off of my Tercel, so I know I'm very close to stock diameter (plus or minus tire wear).
