Yep, TreadLightly is the way to go.....
You still had some stuff space up front, although it looked like you were near max droop on your rear axle
The ranger on 35s should be able to ramp it easily if you've cut enough body away or its high enough. Did you go fiberglass or sawzall with it?
Is the green TJ running air shocks? Don't see any coils, leafs or coilovers on it
