Welcome to Ecomodder.com!
Originally Posted by a8ksh4
Hmmm... I drive a 2WD, 5-Spd, Toyota Tacoma, and have grand hopes to construct an under-body panel for it and some sort of aero-cap to go behind the cab, since I rarely have more than groceries in the back. Aside from my daily 3mi commute to work, I drive quite a bit on the freeway, so improving efficiency at speed would help me lots.
--Dan
First, I suggest starting to log your gas mileage.
Then, I had great success installing a flat bed cover on my 2004 Dodge Dakota 5spd. Another trick that you can do on trucks is to put a performance suspension, lowering kit on. You will drop the truck 2-3" and improve handling.
Good luck.
