Old 01-06-2010, 06:41 PM   #10 (permalink)
Rainh2o
Ecomodder in Training
Rainh2o's Avatar
Green Machine - '96 Ford Contour GL
90 day: 34.9 mpg (US)
Originally Posted by Tygen1 View Post
Zetec does not have the water pump on the Timing belt, you have a 2.0 SPI if that's the case. Are you at DOHC or SOHC? Zetec has the water pump on the accessory belt. No Zetec's (in the US) are interference, although most manuals say they are.
The water pump is located BEHIND the timing belt and to change the pump you would have to pull the timing belt so that's why I changed it, I didnt want to be doing the whole job again in 20k-30k miles. The pump is driven by the accessory belt. It is a DOHC.
From what I found out this engine is a NON-INTERFERENCE engine which means it will freewheel and there will be no bending of valves because there is clearance between the valves and the pistons.
