Originally Posted by alexander.foti
Right. I have a scangauage 2 on my car which has a 9.6 gallon tank.
As the scangauge doesnt have high accuracy on fuel tank size measuremeant I have told it that its 10gallons as per the manual which says round up.
My Question is, does it affect the accuracy as , after a 10 or 20 fillups I have adjusted it to the point where my Miles to empty is now accurate.
Whereas before it used to say emtpy 30 miles before it was actually empty. it now correlates when its actually emtpy.
confused ![Frown](/forum/images/smilies/frown.gif)
Not sure I understand the question but when you fill up the amount you put in the tank should match the amount of fuel used on the SG. Mine was accurate to within .1 gallon almost every fillup once I got it adjusted.
