Old 01-06-2010, 08:17 PM   #25 (permalink)
busypaws
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Just joined this summer so don't have any 2009 resolutions to review.
My commute is 5.5miles and 22 stop lights. So my goals are rotating weight, curb weight and faster warmup times.
In 2009 I was able to loose 17lbs rotating, 157lbs total and zero in me.
2010 goal another 15 rotating, 60 in total and finally 15lbs in me.
Should get me to 50mpg on my commute which would get 58-60mpg on ECO run which equals 100% above EPA.
Easy goals:
VX rims on front with 155/80/13. Already have them on rear. Lighter crankshaft pulley.
Lighter/smaller battery. Some LED lights. Smaller alternator and/or alternator field switch. Better grill block. Kill switch. Cooling fan LED so I can tune grill block.
Stretch Goals:
Smaller/lighter radiator. Aluminum brake drums and/or smaller brakes on rear. Lexan for rear windows. Block heater. Lighter weight exhaust system.
Just Dreaming Goals:
Remove 13 gallon fuel tank. Replace with 5 gallon spare tire well tank. I average 2 months between fillups and removing tank and 7 gallons of gas could save over 100lbs.
