New guy here at Ecomodder, coolest website i have found;
i had some questions:
How should I modify a 1990 Honda Civic "Standard model" hatchback for increased fuel efficiency? Stock except for a newer engine, and it also has the stock 4 spd transmission
I read Aero Civic and the other similar Honda from "Andrew J"
BUT both are newer than my hatchback and i am unsure if their results would be my results????
1: I have concluded that a "Kammback" would be the "most cost effective" modification for improved fuel efficiency...AM I CORRECT???
I liked this one from "Andrew J". i believe he sold the car
1A: IF i can make a Kammback, what should i do first? what is a good blue print to follow?
A; remove or retain the stock spoiler?
B: what angles to attempt to obtain?
C: how big do i make it?
2: What about a "Front Splinter'??
Would this improve fuel efficiency????
3A: What about a transmission swap?
I have the stock 4 speed transmission and want a 5 speed transmission swap IF i can get better MPG : my uncle advised me to keep th 4 spd because it is more durable than a 5 spd transmission ???
3B: I recall someone changed their saturn transmission with very little difference in MPG.. what about my car???
4: HOW and WhY should I "tuft test" ? what is the process? What am i looking for?
Anything else???![Turtle](/forum/images/smilies/turtle.gif)
Please move or do what is needed.
My E-mail. thanks.
tanjulio@hotmail.com
