Old 01-07-2010, 02:12 PM   #42 (permalink)
TEiN
Not wearing pants
Originally Posted by SentraSE-R View Post
It may not be zero, but it's negligible. The soles and heels of your shoes wear away with time, but any individual step you take doesn't wear them much. Any low rpm clutch slip isn't going to wear your clutch much. Drop the clutch at 4500 rpm, or do a shift at redline, and 100 no-gas startups in a parking lot are zero by comparison.
Exactly.
If you rev the engine to 2000 rpms, and smoothly slip the clutch out (or, as smoothly as a beginner can), you've got maybe 20-50hp and 2000 rpms grinding the clutch against the flywheel. That sounds like a fair amount of wear for every single launch.
If the engine is at idle, and you smoothly engage the clutch without any throttle, you've got around 600 rpms and 1 hp.
So, you're right that it's not *actually* zero, but it's near enough to be called zero.
