Old 01-07-2010, 04:37 PM   #5 (permalink)
Daox
Here are the Kumho options:
Kumho Power Star 758
Originally Posted by Kumho's website
Positioned for the classic import market, Power Star delivers good mileage, even wear, low noise and improved wet handling and traction. The Power Star 758 utilizes Kumho’s ESCOT design technology for excellent uniformity and performance.
Special Features
* Good resistance to aquaplaning.
* Improved wet handling and traction.
* Improved comfort and low noise level.
* Increased mileage and even wear.
UTQG - 400 A/B
Weight - 12 lbs.
Tread Depth - 5/16"
Max Load - 906 lbs
Max Inflation Pressure - 35 psi
Kumho Solus KR21
The perfect choice for family transportation, the Solus KR21 is an all-season, premium touring tire that offers high performance, incredible mileage and peace of mind.
The KR21 carries an unprecedented 85,000-mile limited treadwear warranty, which includes road hazard service for the first 25% of wear and 24-hour roadside assistance, which remains in effect for two years from the date of purchase.
Special Features
* Advanced carbon tread compound delivers outstanding wet and dry grip.
* Nylon belt edge layers, normally found in high performance tires, provide a higher degree of durability and stability.
* Full-depth sipes, effective for the life of the tire, cut through water film for greater wet traction and maximize all-season performance, even during harsh winters.
* Jointless, spiral-wound bead bundles isolate road harshness, provide enhanced comfort, lower vibration and allow for a more precise tire to rim fit.
* Kumho’s ESCOT Tension Control technology increases the tension in the bead and shoulder area, providing improved handling and steering response.
UTQG - 640 A/B
Weight - 13.5 lbs.
Tread Depth - 5/16"
Max Load - 957 lbs.
Max Inflation Pressure - 44 psi
