Fubeca,
If you know the specs on you truck, there's a great ecomodder tool to play around with that allows you to adjust air density based on temperature. It might work if you work backwards from your results to get your improved Cd and then play around with air temp.
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Boks
