Old 01-08-2010, 07:31 PM   #16 (permalink)
Rokeby
Gen II Prianista
Rokeby's Avatar
Rokeby,would you use a sanding-sealer and then a marine grade paint,as
one might use on an all-wood Chris Craft?
Aerohead,
I can't tell which one of the options I gave you are asking about.
So I'll address them in turn.
One point on using any type of plywood. Plywood failures typically start at
panel edges that aren't part of a properly executed "two step" epoxy joint.
This due water getting into the end grain in the interior plys. This due
careless prep of the edges. You have to seal up the end grain so it can't suck
up water. This take 3 or 4 coats of straight epoxy. Keep on coating until
when you sand lightly with 100 grit paper there is no indication of the end
grain... smooth and even. Only then is it time to begin the painting preps.
I wouldn't use fir plywood... too much trouble downstream.
On HDO and Signal HDO, you don't need or want to sand, that will just fuzz
up the overlay. Go straight to a good grade oil based, "alkyd," primer. Two
thin coats dry faster/harder than one thick one. Lightly smooth/skuff the
surface with 120 grit abrasive, "sand paper" to most folks.
Then on to high quality alkyd, or one part polyeurethane, top coats. Marine
grade paint is considered the best. But at least when it comes to alkyd paint,
there is general belief that "porch paint" is the same as marine grade.
Sand with 220 between coats.
Painted surfaces that will see service out in the real world will last longer,
and require less downstream upkeep if allowed to dry for 30 days before
being put into service... yeah, not likely. But a week at least.
As to the finish on a classic Chris-Craft type hull, that would be a whole
different world. First off, the hull may be a single layer, or even laminated
of 2 or 3 layers. For the most part it would be treated as solid wood. Some
folks would start with a single purpose sanding sealer. Others start with a
25% varnish, 75% thinner first coat. This just to get the fuzzed up wood
fibers to stand up for sanding, subsequent "prep" coats at 50/50 and then
25/75 thinner/varnish. Further "full strength" varnish coats until the grain is
filled, as many as it takes. (Actually the varnish is thinned 10-15%, and
plasticicers and drying agents are used to doctor the mix to ambient
conditions.) Sanding at this stage with 150.
Only when grain is filled do you start counting varnish coats. How many?
How much time/money do you have to spent? At least 20, 30? Abrasives
gradually get less gritty; 320, 400, 600. Most folks stop there, higher grits
tend to polish as opposed to smooth. Could take 15,000 sheets on a 30 ft
hull.
Down stream, you'll need to do some top coating every year. Varnish just
disappears, it ablates. How many coats depends on UV levels. You want to
be slowly building up, never thinning the total film thickness over time.
Sort of like the 50's era "hand rubbed lacquer" auto finishes.
And that's the short course!
The Following User Says Thank You to Rokeby For This Useful Post:
aerohead (01-09-2010)
