Old 01-08-2010, 10:27 PM   #72 (permalink)
bondo
bondo's Avatar
Seasonal Testing of Aerodynamic Cap
I get my best numbers here in Arkansas from about the first of April till about mid November. When air temperatures drop below 40 degrees, so does my fuel efficiency. Below freezing, it is terrible.
Since all vehicles are subjected to the same conditions, with or without aerodynamic enhancements, those with superior aerodynamics will still get better fuel efficiency than a vehicle with out any aerodynamic modifications. In cold weather, this percentage will be lower.
Aerodynamic add on devices like boattails and aerocaps do produce a larger reduction in aerodynamic drag because of their greater surface areas over that of a front air damn, wheels skirts and other smaller aerodynamic add ons. All of these devices will see a drop in effectiveness in cold air.
The thing to always try to design into any product is functionality and utility. With the areocap I constructed, this was a driving force in the design of the article. My plans were then, as they still are now, to get the product to market. There have been some excellent aerocaps built by others on this site which are done very well along with boattails and other devices which show remarkable reductions in aerodynamic drag. However, in the real world, you have be able to get into your truck bed or be able to park your car in a parking garage and also adhere to 5 mph bumper regs , third brake light and other DOT specs.
My product is intended to replace the old square camper shell, which has poorer aerodynamics than a baseline truck with nothing over the bed. A truck running a squared off camper shell in very cold weather will get worse gas mileage than a truck running an aerocap in the same conditions, the percentage of difference between the two will be less. In warmer air, it is a different case all together.
Bondo
ID:	5310   Click image for larger version
