Good job, Mech,
It appears that you and I are snooping down the same path. Sandia-Livermore has had a project involving opposed pistons and magnetic coupling to reach the compression levels we are talking about.
Ernie Rogers
Originally Posted by Old Mechanic
My design used the 2 stroke and direct injection, with variable compression diesel cycle.
Compression ratios could be as high as 50 to 1 (not a misprint).
Also considered high pressure injection into a heat exchanger to better atomize the mixture for HCCI, using other fuels.
Possibly multi fuel capable with variable compression, or even multiple fuel capable simultaneously.
I think one of the govt research labs is doing research on an engine with the goal of 60%efficiency. I think my integrated engine-flywheel design has the capability to reach that level of efficiency.
regards
Mech
