I thought that it was interesting that the Aptera uses an electric drive similar to a motorcycle rear or my E-Wheel, timing belt and all.
http://www.aptera.com/details.php
Notice the bridgestone Potenza, the same LRR tire as the Insights use.
Many front wheel drive cars have a simple trailing arm suspension.
If the electric motor could be mounted so the rear suspension hinge point was where the motor output shaft was located, the suspension could move through the full range of motion and the timing belt tension would be maintained. The motor would be mounted to the chassis so it would be sprung weight, and the wheel would only be a bit heavier. Using a brushless motor would be best to eliminate the brush friction when the motor was not powered up.
I will be playing with that concept later this year.
The pusher trailer concept should work fine in principal, but I don't like the added length, and the added difficulty in backing up and parking.
A light weight 3 wheel trike like the Aptera, looks like a great configuration. The only thing I would do different is to have the front wheels also lean into turns, and maybe have some pedals so the passenger can contribute to the ride.
