Originally Posted by thatguitarguy
Very nice work! That siding starter strip is a great idea and the cove molding looks like it belongs!
I know you're in a cold area, but I'm curious if the little peephole you left open is enough for when the weather gets warmer?
No it's not. That will only do for around town when it's cold. The center pieces slide in behind the outer ones so it can be opened up as needed. When opened up it was okay on the highway to 50 F last fall so if I'm in town it will be good for warmer than that.
