Old 01-09-2010, 05:17 AM   #2865 (permalink)
jackbauer
jackbauer's Avatar
Positive and negative dc dc converters are readily available. I'm using one in the charger. I'd be looking at putting a serious negative voltage on the gate of the the device your turning off. Just pulling it to ground won't be enough. my 2c.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
