Old 01-09-2010, 06:02 PM   #85 (permalink)
smokeyj
I have the solution. Make a Kammback and belly plate, but instead of using the wimpy cardboard and coroplast (sp?) that others use. Use something a little more solid, like 1/4 inch steel.
Now you will have improved drag caused by a better shape and increased downforce at the speeds you should be driving due to the weight.
