Old 01-10-2010, 01:11 AM   #4 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I wouldn't go with 15* unless you drive slower than 60-65 for the whole trip, you'll likely find that it's too steep.
If I get what you're saying, you basically want to build a Kamm back that is just an extension from the window/roof area, but ends past the deck lid?
As per usual, I always suggest about 12-13 degrees for a DIY project without access to a wind tunnel or a person just wanting to "test everything out" as it were.
Of course, that will put you out a bit further, and you're probably going to lose visibility through the rear window, something to consider... most clear materials distort at that angle, so everything will probably be a colored shadow that you can't really make out very well.
Don't forget to taper in the sides some, at least to match the tail of the car.
