Old 01-10-2010, 09:09 AM   #10 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Originally Posted by luvit View Post
i believe it does work.
is also believe it could be sensitive construction in a number of ways... and results will vary greatly.
i believe a hypermiler can outperform hho, but what if a hypermiler and hho got together.. the improvement my be nominal?
i have all the materials to add hho... but time to do it just isn't here.
There are better hho systems than Water4Gas...but these e-books give a pretty good overview and details on how the various subsystems are typically used.
Ozzie's Toyota is the gas version I think. The purpose of giving the info away free is to have you eventually buy their stuff to assemble a system.
You'd want to start with the most efficient hho generator....which I think would be like the one mentioned in a previous post...very close gap...uses distilled water...produces little heat...and so might be insulated and use a heating element for winter use.
You can buy some high output efficient hho "bricks" for not too much...then you'd build a system around these.
Most on this forum are neophytes...no real experience...they just quote physics laws...i.e...dump a load.
There are commercial companies that sell hho systems for use in over the highway trucks, etc.
Why don't I use one? I tested my own crude design with a low output drawing 10-15 amps and saw either a 10% gain or no gain...with a carbed 4x4...about the most difficult vehicle to see an mpg gain from...espec when was already tweaked for more mpg. Eventually I might try again with an EFI based fuel system. You can easily put a lot of money and time in it...you learn a lot though.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
