Old 01-10-2010, 07:40 PM   #87 (permalink)
tanjulio
Originally Posted by smokeyj View Post
I have the solution. Make a Kammback and belly plate, but instead of using the wimpy cardboard and coroplast (sp?) that others use. Use something a little more solid, like 1/4 inch steel.
Now you will have improved drag caused by a better shape and increased downforce at the speeds you should be driving due to the weight.
I have been looking for a guidelines to follow: How to make a Kammback" which will give me downforce or reduce lift...
METRO MPG, Andrew J, page 8-9 or specific TomO's 'my Kammback VX...etc.
have made a Kammback and had great result with fuel efficiency..
BUT can i have both???
FUEL EFFICIENCY AND DOWN FORCE/REDUCED LIFT??
IF anyone can give me a few links OR Guidelines to follow on the DIY section
my car is a 1990 honda civic hatchback. I think this needs to be addressed for people like me who have No clue as to what to do...a DIY Section!!!
I FOUND THIS FROM METROMPG BUT THERE IS NO CONSENSUS ON A SPECIFIC ANGLE TO STRIVE FOR?????
http://ecomodder.com/forum/showthrea...sion-3518.html
