Old 01-11-2010, 01:38 AM   #25 (permalink)
ChrstphrR
Schwartzejetta - '00 Volkswagen Jetta TDI GL
90 day: 52.87 mpg (US)
Originally Posted by moonmonkey View Post
i think you guys have convinced me i need to go lighter anyway, i think i will go with aluminum flat stock and some form of plastic, i buy alot of (hyzod) "lexan" from a plastic company in jacksonville fl Farco plastics, i will drop by there on monday and see what they have thats "coroplast like" maybe they have something thats stronger and not too heavy
Lexan at 1/8" thick is about 0.78 lbs/square foot, so it's half the weight, roughly, of aluminum.
Coroplast is a light, LIGHT skiff of polyethylene on either side with bits in between to make it rigid ... it's -almost- negligible in weight. And much cheaper than buying lexan.
im driving to raliegh NC in a week or so, a 1000 mile round trip so i want my pan in before i go.
If you can't get it all on before you go, cover the front underside first, and work back... Your biggest gains will be from the bumper to just behind the front axleline. Concentrate on making sure what you attach stays ON, since you're travelling 1000 miles, not on covering everything over. You don't want to have to do a field repair along the way, delaying your trip!
by the way how air tight against the bottom of the car does this need to be, i dont think i can seal it 100% because of the suspention at the wheel wells.
You don't want metal parts or sharp edges abrading against important things like your brake lines, of course. And no plastic near the exhaust.
Until a bunch of us figure out the "ideal belly pan" for a few dozen different makes of cars, it's going to be trial and error. Expect to either be covering underneath in sections, and/or be redoing things as you figure out better ways to attach the materials you'll use.
I "built one to throw away" twice now. One out of coroplast, that didn't last, and one out of perf-steel, that I used mainly for stiffness, and better measurements for mounting points.
And to top it off, the time I'll put into building the 3rd, I probably could just -buy- one of the readily available metal skidplates for my car ( Evolution Atlas Skid Plate For Beetle, Golf & Jetta IV ).
Think through how you'll mount things, first and foremost, and search around the forum here for ideas, too.
Off the top of my head, there was thread with a mustang that had a lexan engine undertray, and an insight with a fibreglass/foam core undertray, and plenty of people using coroplast, too.
Planning and looking at others' ideas will give you ideas, and maybe save you from following a few dead ends.
And, unlike what I've done... post pictures if you start something up!
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
