Thread: hi from boston!
Old 01-11-2010, 10:01 AM   #2 (permalink)
NeilBlanchard
Hi Carolyn & welcome to EM,
You will probably have to check the math on the two routes to get the actual total of fuel needed for each? If the shorter route involves a lot of sitting still, then you probably can help by shutting off the engine when you can (by studying the light cycles, etc.).
