have you accounted for the larger tires in your speed and distance traveled? Your speedometer is really counting revolutions of the output shaft on the transfer case. If you change any of the ratios after that point it will skew your speedometer and odometer. Larger tires means your rig will go farther per revolution of the tire making your mileage not quite as bad.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
