Old 01-11-2010, 10:59 AM   #91 (permalink)
AaronD
Originally Posted by janvos39 View Post
In every head design you have to choose the inlet channel so that at max. torque the inlet speed gets to mach 0.5 (approx 160 m/s at max pistonspeed position) for best performance. Honda made some publications on this subject with formulas added to calculate the best dimensions.
Must have to do with creating sufficient turbulence in the incoming charge for a fast burn then? I guess this is getting a little off topic though so I won't try to guess further.
Beautiful work on those 6 valve heads btw.
Aaron...
