Old 01-11-2010, 02:46 PM   #9 (permalink)
Oval_Overload
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
If you cheap out on the DC/DC, it will cost you. I know a guy who has burned out so many cheap dc/dc units that they collectively have equalled the cost of one high quality unit.
Here is a gentleman in my state who is getting respectable numbers from a forklift motor in a Gen 1 Saturn SC (keep in mind this is a very light car. The body panels can be weighed in ounces :P )
He appears to have found a 72 VDC forklift motor. These are not easy to find, but I think you will be much better off if you take the time to look for one. Plus, with a 72 VDC motor, you can add cooling and over volt it to 84 or 96 VDC for a noticeable increase in power and range. This may require tweaking the brushes (do your homework).
Remember, to keep things economical you can build Paul's Open Revolt controller.
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
