Well try to keep it clean since your aerodynamics are HORRIBLE and just switch back to some stock tires if you have the cash to Unless you actually USE it for offroad. Also you've got the 4 Cylinder jeep try a few small performance things so it'll hum along more easily on the freeway .
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
