I've also been thinking about how to automatically disconnect the dc to dc converter and I think I have it figured out. The idea is to tap into the ethernet line that goes up to the switch up front. This can be done with connectors so install is very easy and no wire cutting is necessary. The switch up front sends a 12v ready signal to the dc to dc converter. I will use that 12V to power the arduino and another relay. The relay will disconnect 12V power after the arduino thus keeping power to the arduino, but cutting it to the dc to dc converter. This will also prevent the arduino from drawing 12V power while the car is off. Thusly, if you turn the PHEV switch up front off, the arduino will power down. When you turn it back on, it will restart the program canceling the 60 minute timer currently built in to the program.
Thoughts?
