Old 01-12-2010, 09:31 PM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
You might have a lower temp thermostat and your ECU might be different, other then that it should have the same catalytic converter right up by the exhaust manifold, and the EGR valve might be different but I'm not sure how, other then that, most of if should be the same or pretty close.
with a 2nd generation CRX (HF?) you should do pretty well, make sure you have light weight wheels (HF, VX, HX or honda Insight wheels) good narrow tires, change your tranny fluid! and give the car a full tune up.
