Old 01-12-2010, 10:23 PM   #100 (permalink)
bondo
bondo's Avatar
Apologize again for slipping off thread.
This is maybe one solution to reduce the swirling eddies formed at the rear corners of a four wheeled vehicle as it passes through the air.
This concept ducts the air and then rudders the flow to maybe dissipate the eddies in size and thereby reduce low pressure areas. Just a concept.
Bondo
ID:	5344   Click image for larger version
ID:	5345   Click image for larger version
