Originally Posted by RandomFact314
BTW, can I just use the stock heat sink until I get a better one? I can pull it off without damage right? Plz let me know
Your stock heatsink will be completely fine if you aren't overclocking yet. In fact, it can probably handle low to moderate overclocking just fine.
Edit:
I haven't messed with heat sinks on that socket type yet, but generally there's just a little latch or something. Quite easy to remove.
However, installing can be harder sometimes because you want to make sure you have a (very thin) coating of thermal paste on the new heatsink when you put it on. Some heatsinks come with it pre-applied, otherwise you'll want to grab some off ebay.
