Old 01-13-2010, 09:51 PM   #3 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Diesel performance guys do this for quick, cheap HP. What you are doing is making the engine a dual-fuel engine. Propane is nothing more than an auxiliary fuel. Propane won't compression-ignite. The injectors squirt some diesel into the chamber and it acts as a spark plug, blowtorching the propane to ignition. The propane, once ignited combusts very quickly, so if you use propane you can't use a lot of injection advance. Too much injection advance and you bend rods.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
Piwoslaw (01-18-2010)
