Thread: It's cold
Old 01-14-2010, 02:43 AM   #1 (permalink)
Dust
The Move - '99 Daihatsu Move Aero Down Custom XX
90 day: 29.89 mpg (US)
Send a message via AIM to Dust
It's cold
It's so cold that my aftermarket water temp gauge flashes at me because it is below the warning point. Ok, it's only just below freezing, but a 650cc engine with a good sized OEM radiator takes most of my drive to work to get the stock needle to the middle, and my aftermarket up to 140F. I have a turbo in the car(OEM), and I have water injection installed pre and post turbo. The intake has a hose attachment that goes behind the headlight. I am thinking about pulling it out and letting it suck air from toward the turbo.
Daihatsu Move pictures 1999
here is a pic. The turbo is above the license plate, and the radiator is on the opposite side.
Also, the top grill is half blocked already(to protect the turbo), and I am considering blocking the other half off too. I will start there, and see how the temps do. If that doesn't work, then I will try to block the bottom half with something attached to the grill, not to the radiator
Anyone see any problems with this?
