Old 01-14-2010, 08:51 PM   #1 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
10 mm vs 4 mm thick coroplast sheets source
i bought 2 sheets of coroplast today for my bellypan, i got a 10 mm thick and a 4 mm, the 4mm is what is normally used for signs, that 10 mm stuff is really tough, it is ridged and not that bendable, it should be very durable under a car, the 4 mm weights 4.16 lbs and the 10 mm weights 5.024 lbs that extra pound makes a huge difference in toughness! the 4 mm is $10.00 a sheet and the 10mml is $28.00 a sheet at farco plastics,(thats a 4'x8' sheet) they have branches in fl,al,tn.but im sure most any med to large town will have a similar store, it is way cheaper thru a plastic/lexan/acrylics supplyer like them than it is from a sign shop, at least it was for me. Belly pan pics coming.(i asked for damaged sheets and they had some in both sizes ,just a little edge damage or small ding "not important to me" and i got both sheets for $29.00.just incase anybody is looking for some of this stuff.
The Following User Says Thank You to moonmonkey For This Useful Post:
Bicycle Bob (01-14-2010)
