Old 01-15-2010, 03:31 AM   #5 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
It's not quite like Nitrous use in a gasser, though... Nitrous is an oxidizer... you can also use it in Diesel engines. Propane is a fuel, and can also be used in gasoline engines.
I wasn't aware that propane won't auto-ignite under compression? Or did you mean under the compression that normally occurs in a combustion engine?
OK - LPG will auto-ignite at ~1000degF, so probably not going to happen in a normal combustion engine.
