I fight the e10 like this (i have ford escort zx2 with e10 about 26 mpg in city
after I started to separate ethanol from my gasoline my improved to milage is 36mpg in the city and I dont even hypermill) I buy/put 2 gallons of 89 and 2 gallons of 92 in to my 5 gallon container(so the octane wont go below the 88) then add a cup of water then let it stand for two days then let the ethanol mixture drain(gravity feed) through brass tube attached to clear fuel tubing into clear container so I can see when to stop. Whole operation takes 10 minutes. Yupee
