Old 03-21-2008, 07:52 PM   #5 (permalink)
CuriousOne
Softcore EcoModder
Originally Posted by RH77 View Post
Welcome to EM --
Depending on the model, there are several things to try -- aero improvements, drivetrain tweaks. WAIs work with certain manufacturers -- but nearly all work in colder climate for warming up the vehicle. Depends on where you are, but an Engine Block Heater may help get you started more efficiently. Perhaps some Low Rolling Resistance tires.
Don't rule out the power of technique and instrumentation/feedback.
I assume you've read the EcoModding for Beginners thread...
Best FE to ya!
RH77
So I guess other than the mods I listed above, the rest are those weird looking aero modifications? Although the drivetrain modification did pass my mind. A lightweight flywheel and lightweight driveshaft would be very useful, along with lightweight rims (not part of the transmission, but reduction of rotational mass is really useful).
About the thread you linked me to, I just read the thread right now and I most of those already.
