Old 01-15-2010, 07:47 PM   #8 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Axial fans can provide high flow and high boost, but not at low cost. They work well on jet aircraft, although the inefficiency is such that small aircraft tap off a bit of compressed air and re-expand it for cabin heat.
Having an extra restriction in the intake is irrelevant if it just takes some of the load off the throttle plate.
I'd like to see a proper device, either axial-flow or positive-displacement that would work as a supercharger occasionally, but as a throttle plate that generates power most of the time. However, messing with intake pressure makes variable compression even more desireable.
